250Gimp
- Jul 13, 2007
- 145
Hi All
Got the engine winterized today and thought I would check with you all on wether I got it all correct.
Boat is a 2006 Maxum 1800 SR3, Merc 4.3l MPI, Alpha 1.
Here is what I did in order: (stabilizer already in full tank)
- Change oil (didn't take as much as it was supposed to)
- Connect fogging mixture into fuel line
- Run motor for 5 minutes, as per manual (not much smoke, thought would be more)
- Change fuel filter
- Open single point drain to drain block and manifolds
- Take boat for trailer ride, aprox. 15km up hill and down, smooth and rough
- Put in antifreeze until comes out drain, and close drain
- Continue adding antifreeze until comes out upper drain and out drains in transom plate.
Next weekend I will change the outdrive oil and change the impeller.
I added the Anti freeze through a port at the top of the casting where the upper drain is. Seems to be the highest point, but I am now second guessing if this was the correct spot to fill from. Any thoughts?
Did I miss anything?
Thanks
CP
Thanks
CP
