funshipbryan
- Jun 13, 2011
- 10
I have spent the last 3 weeks trying to get as much information on winterizing a volvo penta 5.0 gi PEFS engine as I can. I have the small Owner's Manual that came with the boat and I also bought the Clymer Volvo Penta Stern Drive Shop Manual (1994-2000). Being that I am new to everything boating, this has been a confusing endevour. What I have done so far is to removed the two brass bolts on the bottoms of the engine block (stern and port) and also have removed the two brass bolts at the back of both manifolds. I used a small stiff wire to keep poking at these opening while the water was draining to make sure they didnt get plugged up. I then unattached the two larger hoses going into the raw water impeller and allowed any water to drain out. One thing that is in the small owners manual booklet that I have search and search for on the net is what the heck is the Vapor Separator Tank.... there is no picture of it or location of it in the manual, neither the shop manual nor the small manual that says to drain the hose. The exact wording in the small manual is : Remove the water hose clamps and water hoses from the vapor separator tank. I had called a volvo penta dealer and was told it is located between the two fuel pumps and it is a small canister and to just remove the hose and blow in it. I did find a canister looking device between the two fuel pumps that has a metal label that has Carter on it and some numbers, I assume this is it.... there is a small diameter hose going into the top, I removed the clamps and blew in it, nothing felt like it moved, just like blowing into a hose that has no circulation. I have put back in all the bolts, reconnected the hoses, I guess my main question is..... have I done everything I need to do to prevent any freezing this winter. I live in western maryland where it gets into the single digits so I do not want to mess up and crack my engine. Any help or advice would be very much appreciated. Oh, also in the shop manual it says to drain the sx drive, but the picture shows some draining screw on the port side of the drive, which of course there is no screw where the picture shows..... do I need to do anything to the SX drive to winterize that?? I am hoping I can get this down so next year it will be a snap.
Bryan
Bryan
