First time powering
bomberevinrude40
Hello to all First time poster but not last Started off fishing with my 5 year old. Now my wife and everyone is hooked for life. I purchased a bomber bass boat with an open floor plan.meaning all has been gutted and I can do what I want to inside. Now it is time to buy a motor. I have a chance to buy two if these motors for very reasonable. Can anyone help identify please. All help appreciated. I can post model numbers tomorrow when I am physically with the motors. Lastly again all help appreciated. I have read many new posts without followups and then abandoned the post. I will not do that. This is the least I can give back to the forum. Whichever two I buy, I will post pictures and ask questions, I'm sure, about the rebuild. Again. Thank you
Bosunsmate
they all look pretty old apart from the one with the tiller visible, on left in second photo.
test before buying
bomberevinrude40
Thank you. I think I will be safe at $125 a piece don't you? I'm gonna buy 2 of them and rebuild one at the time. Maybe the closest tiller amd the 25hp. I will post model bumbers tomorrow when I'm there. I have a compression test kit I use on all my vehicles. I buy older trucks fix and sell. I'm very familiar with fuel fire amd compression. Can't wait to sink my teeth into an outboard
vasy
Those old motors can't be good on gas or environment. I though for fishing you want quiet and less oil around you.
Why not pickup a small 4 stroke and an etec 2 stroke?
Yes, more $$ but much less noise and way less gas used and more hours spend fishing and less in the shop.
vasy
It really depends on your market and luck.
Brand new 30HP E-tech will run 5k here but of course used market is a crap shoot and so depended on the need to sell and local conditions.
I've seen some got for $2k in good running order and low hours.
Yes, about 10 times more :) but personally I'd pay it from the perspective or much, much quieter engine, no stinky smell when you are fishing and knowledge that you don't pollute the lake you are in while fishing, plus reliability.
When fishing for 4-8 hours at virtually idle, last thing I wanna smell is unburned fuel around me... but that's just me.
Recreational boating is a little different because at higher RPM you almost don't dump any raw fuel/oil into the water and you burn just a bit more gas so cost savings are insignificant and the range in also not a big difference, plus the smell is so far behind you...
bomberevinrude40
thank you for all of your input I am probably going to start on the Evinrude 25 and rebuild it depending upon its contraction because it will be used mostly for recreation tubing, etcetera. The only other time I will use to describe to the fishin hole then switch over to my trolling motor. Thanks again guys
