groundedchevy
- Sep 11, 2012
- 19
I picked up a 67' Starcraft fiberglass boat with a 67' Mercury 650 this December and I'm finally taking it out to the lake on Saturday. The serial number for the motor is #2216585 or #2210585 and I want to make sure the correct fuel
il mixture was 50:1. Any recommendations on which 2 cycle oil to use? Also I planned to use Stabil Marine since most of our fuel has ethanol in it (Is this a good idea)?
The other thing I wanted to do was put together a small toolbox in case something happened on the water. What size recommendations for wrenchs should I take? I'm assuming they are all metric nuts on the Mercury? Any other tools you would suggests to add for the water?
So far I've put the engine on muffs and it has started on the first crank everytime so I hope I don't have problems ::knock on wood::
How often should I change the lower end grease? Is it a pretty simple process? I would consider myself an above average weekend warrior mechanic.
Any other tips first a first time Outboard owner would be much appreciated.
Thanks for all the help in advance.
