DECK SWABBER 58
- Aug 14, 2009
- 1,913
Well I did not scream and yell at the first mate, It was totally my fault. She was devestaded, I put my arm around her and said it's ok, it was an accident, it's just a boat. It can be replaced, we cannot, and were not dead!
I "ASSUMED" that she knew how to run a outboard. She is VERY mechanically inclined, can fix anything, grew up in W.V. mountain's, drove tractors, can fix a car, etc, etc, etc.
After the crash we climbed up on the dock, a young couple on a motorcycle had stopped at the lake and heard what had happened came running down the dock and he helped bail the boat. It never sank thank God. When we got most of the water out my next door neighbor, who also heard the commotion drove me back to get the truck and trailer. We got the boat out of the water and I immediately drained the oil and pulled the plugs, blew all the water out and filled the cylinders with oil. The next day we drove 25 miles to a NAPA, bought gear lube, oil, wd-40, etc. A lot of water came out of the oil drain plug and cylinders, none out of the lower unit. Changed everything including the gas and that evening headed back to the launch to see if it would run. Had disconnected the batt. so just tried to pull start it. NOPE. Thought oh well here goes nothing, connected the batt. and used the starter. It cranked and cranked, coughed and sputtered and finally started
Ok now lets go run it and dry it out. Idled a little rough but mostly ran like a top. Got it good and warmed up and then pulled back out and drained the oil again.
The next morn. it was time to put it back in the lake as we were at the beginning of our week. Backed down the ramp, got in the boat, started the motor, jumped out of the boat, jumped into the truck and pulled boat back out.:redface: What's wrong said the 1st mate? No drain plug said the captain
Let boat drain, put plug in, launch and
can you believe it the rest of the week went without a hitch, and the motor ran great. Still does
The new boat has some major bruises but no popped welds or rivets. For punishment the 1st mate gets to sit and look at the big crease at her feet as we bounce on the waves and wonder??!!!!
Well, in the first month of boat ownership I feel like I made every mistake you can make. Have I exorscised all of the boat demons???!!!! Unfortunately I think I already know the answer!
Voyager builds one hell of a boat and tohatsu/nissan builds one hell of a motor.
