firing order
meggy73123
hey what is the firing order on mercury inline 6 115 hp, 1985 does the top plug go to top cylinder 2nd plug go to 2nd cylinder and so on? thanks
gwukena
Re: firing order
Don't need to worry about firing order, Plug wires go from top to bottom as I replied to in your other post.
If really want to know the firing order, should be stamped on spark plug water jacket cover
sschefer
Re: firing order
Gerry, I've got one of these in the shop right now and the switch boxes are wired for 1-5-3-6-2-4
1 and 6 share trigger coil (1), 5 and 2 share trigger coil (2) and 3 and 4 share trigger coil (3). Switch box #1 inner is set up so the top lug wire goes to #1 coil, middle goes to #5 coil, bottom goes to #3 coil. The outer switch box is wired with top lug wire to #6 coil, middle to #2 coil and bottom to # 4 coil. The top three coil plug wires go to cylinders 1, 2, 3 and the bottom go to cylinder 4, 5, 6.
I'm pretty sure that's correct for 1985 I6 90 and 115. The Merc manual seems to agree.
meggy73123
Re: firing order
thanks appreciate it !
gwukena
Re: firing order
The firing order is not 1-5-3-6-2-4, it is as Gerry stated 1-4-5-2-3-6. The switchboxes are layed out top to bottom wiring as such 1-5-3-6-2-4.
carholme
Re: firing order
Good for you gwukena, I wasn't going to argue the point. I thought he would figure it out in the end, especially as he said he had one in his shop. Thanks for the backup.
Gerry
Faztbullet
Re: firing order
3 & 6 share the same coil as do 2 & 5 and 1 & 4
