Firing order and motorolla breaker less ign
wswaneyw
The firing order on my head says 1, 3, 2, 4. On my distributor it is marked the same way. My question,,, is # 1 on the top or is #4 and should the wires coming off the distributor which are numbered 1 thru 4 go to the coinciding cylinder, i.e. 1 to 1, 2 to 2, ect?
alcan
Re: Firing order and motorolla breaker less ign
#1 is the top. #1 wire should go to #1 plug.
wswaneyw
I figured out the problem. I should have looked at the firing order before I did anything else. I bought the engine last year and put it on my project boat. Engine wouldnt idle very well or go over 4000 rpms WOT. I did take it out again and the original owner had the #1 to the #4 cylinder and the #4 to the #1 cylinder. As i figure it, I was running on two cylinders all the time. After switching the wires to where they need to go,, it idles perfectly and I suspect I will get higher than 4000rpms WOT now too. Such a simple thing for me to miss,,, but sometimes the simple things are overlooked.
