Re: Fire Place
Yea, No argument at all here. I actually didn't hear the last report of the wife and kids that didn't make it. Last I heard is that they were taken to the hospital and put into hyperbolic (sp??)chambers, that is aweful. And Radar, you are right. Some of these power vented systems aren't even installed to code to begin with. Much too low to the ground, under decks!, and under windows! Just went to a job the other day and they had an oil furnace power vented out the side of the house -- fine, but then they had been complaining of smelling "oil fumes" in the warmer months...come to find out it vented out the wall 4ft below the living room window!! It's hard to believe that the building inspectors dont catch these problems at final inspection. The problem with power venting gas appliances is that it will not melt snow or ice because of its very low vented temperature, causing the PVC vent to be blocked. And Radar, your right, the sensors mounted on the gas furnace draft hoods are a joke! I personally have never heard of one working correctly. Seen to many blocked gas flues and the furnace is still cooking away with heat and carbon monoxide blasting out the draft hood -- those sensors work real good! Lastly, GO PATS!!
