This is probably the most important part of installing a fishfinder so any advice appreciated.
I have a Starcraft Islander 221 and a Humminbird 597ci HD DI.
Here is the transom.
I've read the manual and it suggests the right side. And that's a good thing as there are fittings on the left side.
The manual also suggests not mounting it right over the bunk and not to far outboard. So mounting it inside the bunk seems logical. But when you look at the bottom of the boat there is a small strake 5 feet forward. The manual suggests not mounting the transducer at the end of a strake but what about this situation?
On the other side of the bunk there is a strake that terminates at the transom, so thats no good. But there are a few inches which it could mount on the inboard side. And the Sternmate manual suggests the inboard side of a strake is better than the outboard side.
The inboard side of the bunk is only 16 or 17 inches from the centerline of the boat. I feel that may be to close to the leg?
If the boat is firmly on the trailer I cannot see how it could go forward enough to damage the transducer. Unless of course I miss the trailer at speed but then I will have much bigger problems anyway.
Do they caution this because the boat could come down and crush the transducer? With the Sternmate mount, it will be positioned back a couple more inches anyway.
