Finding outdrive gear ratio?
prc03sx195
Where do I find this information? I have a 2003 Glaston Mercruiser 4.3L Alpha one outdrive. Is this a standard ratio documented somewhere?
paul
fuzzybob
Re: Finding outdrive gear ratio?
It should be on the decal on the port side of the drive. The decal should have the serial number followed by R 1.84. That is the standard ratio for the 4.3. If the decal is gone it's normally stamped into the drive under the decal.
prc03sx195
How confident are you in that ratio? My boat is in storage and I don't have access to it to actually check.
I'm just doing some slip calculations for different props and this is one of the inputs.
Is that the std ratio that is used for this engine/outdrive?
Thanks again.
paul
Fun Times
Thanks again.
paul
Here is a list of gear ratios they offer.http://www.mtboats.com/outdrivegearratios.html
If you can post either your engine or drive serial number I might be able to tell you what ratio you have later tonight.:)
