Finding 9.9 Water pump/impeller repair kit
lakelover
I'm having trouble locating the right kit for servicing the water pump for an '05 9.9...I've found what I think is the right one, but all I can seem to find is a replacement impeller. So how do I locate the right gaskets, o-rings etc. for the job?
When I did my 20 a couple years ago, it was simple. I went to Mercury Parts Express, put in my serial number, and got a diagram with part numbers that I could order right on the site. No such luck there now, it looks as though everything has changed on the site. Other sites are scant on detailed info so I'm not confident of ordering the right parts.
Serial number is 0T910996. Any suggestions?
Shadow662
Re: Finding 9.9 Water pump/impeller repair kit
Ok, right here is what I think you are looking for. Double check the SN. Or you can got to mercruiserparts.com and put in mode/SN and search for water pump instead of looking threw all the diagrams. Here is what I found
http://www.mercruiserparts.com/Show...c=Gear+Housing(Driveshaft)(2.00:1+Gear+Ratio)
And at the bottom is part #46-42089A5. Click the link shown in ble and it shows the parts blown up.
lakelover
Thanks for heading me in the right direction, shadow.
