I have a 16ft. Fin and Feather that was made in Bartow Florida in 1999. I bought the boat used and when I drilled a hole in the floor to install a beilge pump switch water came up through the hole. The boat has a floor and a sub floor. The water is in between the floor and sub-floor. I had used the boat 4 times and I got about 3 gal. of water out. Since then if I use the boat 4-6 hours of fishing I drain out about a quart and a half of water. I drilled a hole large enough to get a soda straw into and suck out the water with a syringe. I have tried to see if there was a crack in the hull and can not find one. Anyone have any ideas on where my leak is. The last three times out I get about the same amount of water out.
