filling trim reservoir
timmee73
I just replaced my trim motor and am wondering how full to fill my res. also if it is just hydraulic fluid or something special. My motor is a 91 mercury outboard 115hp #OD 043345. Thanks
Chris1956
Re: filling trim reservoir
Tim, Normally you tilt the motor all the way up, boat level, and remove the plug on the resvoir. Fill it with auto trans fluid (ATF), until some runs out the fill hole. You may need to bleed the unit, by running it up and down a couple of times. now leave it up for a few minutes to let the air bubble out and refill the resvoir. Repeat as necessary.
