Re: Ficht Rebuild Opinions
I'm almost certain excessive carbon killed the first powerhead. I took the motor to a dealer for a software and hardware upgrade in the spring of '98. As part of the upgrade, I was told the oil return line check valve was replaced. Well, the dealer installed it backwards and the first time I ran it, all the oil was pumped into the motor. You should have seen the smoke!!!<br /><br />I ran it less than a quarter mile, but used over a gallon of oil. I didn't know about decarbonizing and was never informed of this by the dealer, so it wasn't too much longer afterwards that the motor went bye-bye. Surprizingly, the dealer did admit he installed the check valve in reverse, but the idiot never even apologized. <br /><br />I had to fight with OMC to replace the powerhead because it was technically out of warranty (only 1 yr warranty back then); however, they replaced it with an original design 97, not the newer style like Dhadley mentioned earlier. <br /><br />After that incident, the motor was never the same. Even with the new powerhead, it missed from about 1200 - 2800 rpms and fouled plugs like I've never seen. I made numerous calls to no avail to OMC engineers and management, but no one would admit that the engine and fuel injection system was compromised by the excessive oil. <br /><br />I even contacted Bombardier several times when they took over thinking a new company might help, but they flat out told me they were not providing service or support on 99 and older Fichts. Sooooooooooooo, I accepted my situation and hoped that the motor would last. Well, I am living proof of Murphy's Law!<br /><br />Why the it went the second time is anyone's guess because I had been using an anti-carbon additive, thanks to the info on this site and others, and I had just performed my decarbonizing routine of spraying Deep Creep (SeaFoam spray) into the cylinders and letting it sit for a day or so. <br /><br />I must admit though, that I was using standard TCW-3 oil and not using any of the newer XD Bombardier oils; however, this is the oil I had been using since 1999. <br /><br />Anyway, sorry for the long post. It's so frustrating to spend that kind of money and get no help when things go bad. Thanks for the replies.<br />Jim
