glen whitley
Thread starter- Joined
- Jan 25, 2004
- 8
I have 99 225 evindude ficht model e225fpleeo has<br />200 hrs. on it. Its boggs and cut out comming out of the hole .But when it get up it run great<br />does not cut out or anything turning 5900 rpm<br />does not give any codes I pull all the plugs out <br />#1 and #3 turn black #2,4,5,6 was good. All cylinder are fireing done a spark test at 7/16 gap,check comp.110,110,110,115,112,112 all the injecter are fireing,check volts to injecter,<br />check crankshift senor,fuel pressure ok,28psi<br />new pump&vaporsepartor no fuel in hose at #4 intake, good battery,check ground to ecu with key<br />on-no volts.Done a cylinder drop test #2,4,5,6,<br />drop ok,but #1 and #3 wouldnot, done one at 1500<br />rpm and one at 3500 will not drop tested at ramp<br />done syn-link too,check lift pump,plugs are index.ANY SUGGESTION.PS. its on a stratos 21 ss extreme boat.prop is same one before its started this prop is ok.
