I just purchased a 1995 mastercraft 200 vrs and have put 50 hrs on it this summer. I started getting a ferocious leak that I believe I have localized to the starboard exhause silencer. I think I feel a crack on the back side of it and am prepping materials to hopefully fix it. I was wondering if someone knows what kind of epoxy would be best. the West marine around here has the 650 flex stuff rated at 150,000 psi. the jp weld stuff at Academy is 4000. is there are difference? any experience with this problem?
Leak details in case you have another idea for what is going on:
I get a pretty rapid leak from that area when running the boat in the driveway. it fills the bilge up pretty rapidly as well when I put it in the water, but it then stalls out and doesn't seem to leak super fast while out on the water thereafter. I don't see water leaking from the block anywhere, and I recently fixed a stuffing box leak.
thanks
thanks
