Re: Fiberglass crack repair in sunfish
jeez...how big is the crack? technically, your correct. realistically, depending on how much the boat is worth, you can probably get by drilling out both ends of the crack, use a keyhole saw to cut along the crack (making a 1/8" line between holes), and filling it with a fiberglass resin/microfiber mix. sand, finish, and sail. its not as strong a finish as the correct way, but its fast, and so long as its not at a stress point, will probably last the life of the boat.
