fiber-glass transom repair
Eddie1920
Well the other day i took off hard and heard crack at the rear end i stoped to check and sure enough i hade cracked the transom pretty good. it also Made the wood under the fiber glass visable and it is all roded out bad. How Do i go about fixing this. i know what to do i just need to Know How. all the wood needs to be replaced back there and then refiber glassed. thanks
Re: fiber-glass transom repair
Ayuh,...............
1st ya gotta Take Everything Apart...............
Then you can Put it Back Together.........
But,.......
Until you Take it Apart,...... You won't know What you Need.........
studlymandingo
Post this in the restoration and building forum and you are likely to get tons of good advice.
As Bond-o said, you gotta take it apart first.​
