agallant80
- Oct 25, 2010
- 2,328
Hello all.
I have posted a few threads on the individual issues but this weekend I had all of the issues with my bravo3 drive and figured that I would lump all of the issues in to the same thread, perhaps they are related. With that said this is a pretty much new setup. I bought the boat in Feb of this year and have about 25-30 hours on it. Also, I know a few of you will think "just take it back to the dealer" The dealer I bought it from is 300 miles away I don't want to spend a weekend and two tanks of gass to drop it off and another weekend and two tanks of gas to pick it up to find out they missed somyething. I don't want to lose my boat for how ever long it will take another Mercruiser dealer to look at it, I am sure they are busy servicing boats that were sold at their dealer. I am posing because I am interested in learning more and figuring it out on my own with help from the iboats community of course
Issue #1:
Drive sounds like it is grinding when turning, if going strait it does not make any grinding noise, I am going to pull the drive Tuesday night and look at the u-joints, gimble, alignment etc. Is there anything else that I should keep an eye out for?
Issue #2:
The drive will shift between netural, forward, and reverse fine but when I run it for an extended time say an hour or so It will do a few funny things. Some times the shift lever will get stuck in forward and I will have to juggle it around to get it to go in to netural. The other issues is sometimes when I put it in to gear it does not engage. The motor will rev up and some times it will slam in to gear after the motor reves up and some times I have to put it in to netural then forward to get it to engage. I am going to look at the shift cable ajustment but don't know if I should be looking for anything else.
Issue#3
There seams to be a ticking noise coming from the rear of the motor. With the motor running I was listening for it, thought it may have been valve noise but when I investigated further it was coming from the rear of the motor. Any thoughts on this one? The noise was pretty bad, it reminded me of my Diesel truck. Perhaps related to ussie #1
Thanks for your help guys.
Issue #1:
Issue #2:
Issue#3
