Pokertrampp
- Sep 17, 2009
- 279
How can I tell if I have either of these features, and how do I disable them to adjust the timing. I read a post here that mentioned if I do not disable them it could make my motor run rough, which is the problem I am having. (1988 Johnson 120 (J120TLCC)). There seems to be some confusion in the threads I have found, some say disconnect the black wire with white srtip, some say white wire with black stripe and others say yellow wire with red stripe...which is it, also some say to ground the wire after disconnecting it and others say leave it floating.
