fast idle lever
Status
Not open for further replies.
jordan23
I have a original remote control for my 84 70 hp johnson....What is the fast idle lever used for???Its on top of the remote ,with a picture of a book on it? :confused:
jordan23
Re: fast idle lever
Thanks man!! knw its a newbie question , but didnt knw so...........apprct. it:D
ezmobee
Re: fast idle lever
I'd have a pretty tough time starting mine without liberal application of fast idle lever.
jordan23
Re: fast idle lever
How does it work excatly? Do you lift the lever up first ,and then start the the engine or?
ezmobee
Re: fast idle lever
Yes. Lift the fast idle lever, turn the key while pushing it in (to choke/prime it) until it starts. Then, if it's a cold start, I usually have to push the key in a couple more times until it starts to rev up. Then lower the fast idle lever.
Home Cookin'
Re: fast idle lever
don't shift with the fast idle lever up, even if you have to drop it and jam into gear at almost the same time.
I wonder why it has a picture of a book on it?
Silvertip
Re: fast idle lever
You cannot shift with the fast idle lever raised as the two are interlocked to prevent this move. If you can shift with the lever raised, something is broken and you are now running a dangerous boat.
jordan23
Re: fast idle lever
Have not put it in gear while the lever is up. Nor will I try it to see if its broken by putting it in gear while the lever is up.....I will take my chances.....................................
jordan23
Re: fast idle lever
Prob telling the operator to read the owners manual..That was my guess
Status
