Faria temp. gauges
pursuit2460
I just bought 2 Faria temp. gauges to replace the other ones that I had. Question is is their a specific temp. sending unit that has to go with it or will the oem ones work. And also does anyone know the thread size for the temp. sensor. Thanks
Mod2
Re: Faria temp. gauges
Moving to Electrics/Electronics Forum.
Silvertip
Honorary Supreme Mariner
Temp sensors need to match the gauge. You will do no damage to the gauges by using the existing sensor(s). If they register normal you are good to go. If readings appear low or high, new sensors are needed. As for thread size, we have no idea what engine(s) you have so can't be any help there.
