FAQ : V6 Mercury Cooling System, draft
achris
More fish than mountain goat
Theory of Ops. V6 merc cooling system.<br /><br />V6 Mercurys use a ‘high pressure-low volume’ water pump.<br /><br />The operation of the water pump is as follows:<br /><br />The pump consists of a housing, an impeller, a base plate with cutouts in it, and an assortment of gaskets. The impeller is ‘offset’ in the housing towards the front. This creates a small chamber at the front with gradually increasing sized chambers at the back. As the impeller turns in the housing the chamber between any 2 blades is constantly changing. This is how the pump moves water. The opening in the base is on one side of the impeller and as the chamber gets bigger it sucks the water in. When the chamber approaches the back of the pump it reaches an opening in the housing that is connected to the water tube that takes the water up to the engine. As the engine speed increases the rubber blades start to fold over and the pump changes from a displacement pump to a centrifugal pump. The speed of this ‘change-over’ is usually around 1800-2000 RPM.<br /><br />Cooling the power-head.<br /><br />Once the water leaves the pump it moves up the water tube and enters the exhaust plates of the engine. It moves between the inner and outer plate before entering the engine block through channels around the edges of the exhaust chamber. The water cools each side of the block and moves into the cylinder heads. Once in the cylinder heads it can take one of 2 paths depending on the output pressure of the pump. If the water pressure has reached the opening pressure of the poppet valve, located on the lower right hand side of the engine block, the valve will open and the water will flow through it and then spray into the exhaust tube as it leaves the engine. This ‘full flow’ allows maximum cooling for the engine. If the water pressure is not enough to open the poppet, then the water will be warmed in the cylinder heads and block until the opening temperature of the thermostats is reached, usually around 140 degrees F. When the thermostats open the hot water can move through and out of the engine, again into the exhaust, until cooler water closes the thermostats. A small amount of water is allowed to pass the thermostats, through a small vent hole in it, in order to alleviate the problem of a pocket of cooler water around them not allowing them to open. <br /><br />At lower engine speeds the engine temperature is ‘thermostat controlled’, where as at the higher engine speeds it is pressure controlled. Usually in operation the temperature gauge, if fitted, will show a higher temperature at trolling speeds than at cruising speeds. This is to reduce the problem of fouling/oiling at low speed, due to too low an engine temperature. <br /><br /><br />Comments, suggestions, additions and beer are all welcome.<br /><br />Chris............
KCLOST
Re: FAQ : V6 Mercury Cooling System, draft
I agree, except in my experience, the highest temperatures are reached at WOT conditions.. This temperature however, is in regards to head temp. "metal". Which most Black Max (late 70's to early 90's motors) had temperature guages measuring. METAL....<br /><br />If the temp sensor is measuring metal at the head, near the #1 or #2 cylinder, it is just above the combustion chamber... In this case, the highest temps will be reached at the Highest RPMs, because cooling water at the top most part of the head remains "somewhat" stable in volume after the stats open and the poppet opens. Stable enough, not no keep the head temp. from raising slightly from what I would estimate 3500-6000 rpms. (3500 refering to the poppet valve opening point).<br /> <br />Now, this doesn't necessarily mean that the the WATER temperature will rise to reflect that... At higher rpms there is much more water flushing through the "entire" cooling system. So more water cooling the block doesn't necessarily mean that the water temp. will increase... It's not an exponential system in that regard, due to the stats and poppet...<br /><br />However I agree that higher temps are likely at trolling speeds rather than at cruising.. But above that it will get it's hottest...<br />I hope this helps...
achris
I agree with all that, and the fact that the temp sensor is measuring metal temp. And the higher temp at WOT. <br /><br />So, any changes to the first post?<br /><br />Chris.........
achris
Bump....
achris
Bump....
JB
That is a nice and well written description of the theory of operation, AChris.<br /><br />What specific "Frequently Asked" question does it answer?<br /><br />How are KClost's comments incorporated?
achris
Will modify first post to incorparate suggestions....
Chris1956
Chris and others, Is there a Water Flow description for an inline 6 Merc?
garyj
I am now having cooling problems with my V-6. The following list is some of the questions I have asked. Anyone want to add to the list???<br />I would like to see a separate description of each subject below in layman's terms (I need simple)..<br /><br />What are the intricate parts of the V-6 cooling system and how do they work?<br /><br />Optimum Operating Temperature<br />Low rpm’s – mid rpm’s – High rpm’s<br /><br />Water Flow<br />Description of water flow from intake to exhaust.<br /><br />Water Pump <br />Housing and Impeller - Parts breakdown and description of how it operates – How to inspect - When should it be serviced or changed<br /><br />Water Pressure<br />How much water pressure is required at what rpm’s. How and where to install a pressure gauge.<br /><br />Thermostats<br />Parts breakdown – description of how they work, degree of thermostat – how to test thermostats<br /><br />Poppet Valve<br />Parts breakdown – description of how it works – how to inspect and rebuild if necessary.<br /><br />Flow Hoses and Tell Tale<br />What should be expected at the tell tale, i.e. steam, hot, warm water, when and at what rpm.<br /><br />Exhaust Discharge<br />How to visually check for proper water discharge<br /><br />Heat Sensors and Alarms<br />Where sensors and alarms are located – can sensors and heat gauges be added (how), how to test sensors and alarms – description of metal vs. water sensors.<br /><br />Other factors that may affect cooling<br />Running lean - Oil injection not working properly - Ignition timing - etc..<br /><br />Southern Catfisher :)
garyj
Chris1956,<br /> I got the V-6 water flow from "achris". (thanks mate) I don't have a diagram for the inline. Didn't see one in my Seloc manual. Sorry :( <br /><br />Southern Catfisher :)
Chris1956
Southern Catfisher - The water flow on the inline six seems to be a well-kept secret. I have had the motor torn apart as part of some rebuilds, and I still cannot figure all of the cooling water flow. I think the water flow is up the block, over the cylinders (port side) under the inner water jacket cover, over the top of the motor where is splits into cooling water for the head and cooling water for the exhaust baffle. At that point the water that cooled the head exits through the grating above the prop and the water that cooled the exhaust exits through the prop.<br /><br />Can anyone confirm this?
