tigerfishes
- Jun 29, 2010
- 18
just read on another thread about an anti-syphon on a tank. that got me thinking about my failed attempts to get my boat in the water last weekend. I'll describe what happened and see if it's a problem.
filled the tank most the way up... prior to that there had been no fuel smells. now when sitting or none when running. once i filled it up at the gas station and then drove about 5 miles to the lake, when we got into it i could smell fuel. couldn't tell where it was coming from and wasn't real strong. lifted the dog house and it wasn't there...but on we pressed. this is before anyting was done because this is where we figured out that i had forgotten the keys at home...
try number 2... back to the lake after getting the keys... still have the smell, not any worse so in the water we go... batter is dead... won't start. it was/is a almost new batt that just got charged. to the store... now have a new one with 875 cranking amps...
try number 3... boats on trailer, in the water... won't start. can't tell if flooded or no fuel? still smell fuel. pull dog house off while waiting for neg batt wire to cool... see something wet on port side back corner. water? doesn't feel like water... it goes up the side to above the water... it's soaked... and it smells like... FUEL!... shut everything down and pull out of the water. next day we find that the rubber fuel line is about 5-10 years past it's life time.
here's my question. i can understand why it would leak with the pump on... but why did it start leaking before any pressure was added to the line? it was like as soon as the level of fuel in the tank was above a certain point the line started leaking. should this be happening? is this a problem?
thanks!
thanks!
