faded hoods on pwc? read this quick fix!
piratedude
if your plastic hoods /covers are sun faded try painting clear spray paint on it and viola! shiney new look! make sure you clean all smuges off b4 painting.
Jeff Walkowiak
Re: faded hoods on pwc? read this quick fix!
That may do ok for a while but it will soon yellow and crack, get some 3m superduty buffing compound and a slow buffer and it will look like new, put on some paste wax , even the plastic hoods will buff, if you have the sea doo handlebar cover that turns white or faded use a little carb cleaner and a scrunge pad to remove the bad part of the surface be carefull not to get it on the decals and do a small portion at a time, then wipe it with brakefluid.
