Factory Compression ?
RonsRanger361V
Been searching all over the internet with no luck trying to find out what the original factory compression was on a 1989 Yamaha 150 ProV. Wondering if anyone has or knows this information. Reason I am searching is my Ranger has this motor. I am showing 110 PSI across all 6 cylinders. Motor runs smooth and strong with no problems. I would just like to know how far I am from the original compression when the motor was new.
Any help greatly appreciated
Thanks,
Ron
robert graham
Re: Factory Compression ?
There's no real factory specs on compression, but all readings should be within 10% of each other...sounds like your motor is healthy! A much lower compression reading in one or more cylinders indicates a problem like stuck rings or scored cylinder walls in those cylinders. Good idea to run that Ringfree all the time so carbon don't stick those rings! Good Luck!
RonsRanger361V
Thanks for the reply. I do add the Ringfree with every fill up. I was just wordering the compression on that motor new out of the box in 1989. Not sure if it was in the 150 range or lower.....higher?
robert graham
I believe compression readings in the 110PSI to 150PSI, all cylinders within 10%, is considered healthy and normal. There is also a leak-down test that can be of value to evaluate a cylinder's sealing abilities. If your rings are free, clean and seated by proper break-in and your cylinders are smooth, then you should be good to go! Good Luck!:)
