I have a Yamaha 2004 4 Stroke 90hp motor that idles rough and when accelerating then cuts out entirely. I have read many posts, and they vary from clean fuel to cleaning carbs, etc. (Yes I left the engine alone for +6months without starting, so initially suspected the fuel to be bad) I have stripped and cleaned the 4 carbs with carb cleaner (They did have a sticky grunge in them initially), and checked the 2 larger jets, and the absolutely minuscule channels that appear to lead to the idle vents in the main chamber, and all are clean and allow fuel to pass through. I removed all the old fuel from the tank, flushed the fuel pipe to the filter and pump. I cleaned out the filter, not much in that, Cleaned out the pump, no noticeable grunge in there either. (did clean the carbs several times as initially I did not clean the smaller idle channels) . The carbs have no adjustments in them at all, the only adjustment I see are the linkages to sync all carbs together.
On many responds the comment clean the carbs comes up, I am wondering if there is something else on these carbs that I am missing, so if anyone knows something specific about these, please can you mention it here - I have removed them several times, so it is getting easier to do
I do know that 2 of the carbs have a solenoid switch (I have no idea what this does - seems to link to 3 orifices in the carb and has a pin down the center one) and attachment to them, and there is a line between these 2 carbs to the other corresponding 2 (ie Carb 1 has solenoid and is linked to carb 2, Carb 3 has solenoid and is linked to carb 4). These solenoids do get warm whilst I am at idle speed, so assume they are doing something but not sure.
I have cleaned all plugs, and checked there is a spark on the 2 coils that are in place (coil 1 -cylinder1&4, Coil 2 - cylinder2&3) , did swap them around to see if any difference, but none. The fuel pump definitely is pumping fuel > 10psi (max my gague went), and the float chambers do appear to have fuel in them.
Any help or direction will be very much appreciated.
