I have a 2002 F200L, I removed the injectors after reading posts of fuel delivery problems. Very helpful. I replaced filters, cleaned the VST, fuel rails and injectors with carb cleaner. It sounds like a sewing machine! (great!)
Upon inspection of the injectors I noted that one was missing a filter, I will need to purchase and replace, not a problem. How do you remove said filter from other injectors without damage to either item? And do they snap in or is there a trick? Thanks Dan
