F200 no compression
Neng1987
Hey, so I recently bought a boat with motor not running. I look up the value for the hull only and basically pay what it’s worth. Engine is a f200 v6 800hrs 2007, port side 3 cylinders all read 130 and starboard 2 reads 160 and the bottom reads 5-10. I won’t be getting the boat to a shop until I redo the brakes and grease fittings on the trailer. What are the possible causes? When removing all 6 spark plugs the one with no compression had a little bit of dark oil coming out.
