tundratoad
- Aug 6, 2013
- 4
Have read most all the post about yamahas surging and it appears no one has ever fixed this problem. Or at least that would seem to be the case since no one has posted what they did to fix the problem. Lots of people seem to believe this to be a fuel problem and it does indeed smack of that my problem with that is, if you have a fuel problem one minute and you don't do anything to fix it, how does it go away the next minute, or less? What I am referring to is the difference in my problem and other post on this issue. My engine can be surging violently when the throttle is advanced. But if you turn the ignition off return the throttle to neutral and restart the engine might very well take off just like nothing was ever wrong with it. To me, this does not fit the fuel supply, or fuel quality failure characteristics I am familiar with. This problem screams brain box to me, that is why I changed the ECU but I still have the problem and it is the exact same problem. I have done a lot of things to this motor to include all the recommendations previously posted. What I am hoping iis that someone has in fact fixed this problem and can will see my post and tell me what they did that fixed it. I am really at my wits end with this thing. And please tell me what a VST tank and or filter are there is a ton of dialoge about them and I seem to be the only one that doesn't have a clue what is being talked about. Everything I can find with regard to fuel has been cleaned changed or otherwise inspected, bypassed or thought to be performing as advertised.
Thanks a ton for any help anyone will be so kind as to offer.
Herb
Herb
