I need some help here with prop selection. I bought a 2002 F115 and installed it. It runs great but i need to get the right prop for this thing. The prop that came with the motor had the inner flange ground off (possibly by a downrigger cable or something ) and my local prop guy said that exhaust was exiting in front of the prop and making the prop slip. So I bought another 13.25 X 17 aluminum prop and tried it yesterday. There was some improvement but it still revs out to 6500 RPM at max throttle and the boat is going 35 knts on my GPS. The boat doesn't get on plane until over 4000 Rpm and my old motor(a 120 HP 2 stroke) got on plane about 3500-3600 RPM. I suspect I need to move up to at 19 pitch but I don't want to buy yet another prop that I don't need. I believe the ratio for this motor is 13:28 (2.15) The dry weight of my boat is 1700 lbs. With fuel, gear and the motor I believe weight is about 2500 lbs. It is a Malibu 182 V hull with 25 deg deadrise. Any thoughts on my next step?
