Couple things first, barn find. 78 Mercury Black Max 1500v 150hp. Amazing condition for the years it has been sitting. Mice ate through a couple wires in engine, already fixed those. Installed new ignition switch, yes the wires are in the correct spot. New battery, new plugs, wires are still great, carbs look good. Everything moves smoothly with no ruff or tightness in carbs, lines, or throttle cables. Pumped out all old gas, which was maybe 5 cups. Lines are clear of any debris. Full tank of 91 with 50/1 prem oil mix. New fuel bulb, new filter, engine can receive fuel fine.
Problem is the engine starts fine but then revs immediately to almost full throttle. Revs immediately up to about 3500 rpm and slowly climes higher. Obviously I didn't run it very long after this. My control box has a push to choke button which closes the front side of carbs. Just trying random things to see if anything was wrong or tight pushing this button restricts the air flow enough to bring the engine down to a normal level, but obviously choking it out soon after. As soon as i release the button it revs back up again.
I know my basics around mercs and helped plenty of people with their new merc engines but ive never owned or been around something quite like this engine. I'm astounded that it runs like it, if only i can figure out what is causing this problem i think she'll run great. Thanks.
