Re: Extracting old gas
I recently drained 25 gallons from my tanks. here is what I did:<br /><br />Went to local auto parts store and purchased the cheapest electric fuel pump they had ($19.99) The pump has a 3/8 inch inlet and outlet. Hooked the inlet to the outboard's fuel line coming from the fuel tank, and hooked a 4' piece of hose to the outlet side of fuel pump. I installed alligator clips to the electrical wiring and hooked it up to a battery. Drained 25 gallons safely and quickly; plus, I can use it over and over if needed. Sure beats worrying about fire or explosion.<br /><br />Then I used the old gas in my Dodge truck. It did not even burp!
