Extra Long Leg
gusthewonderslug
Guys is there an extra long leg version of an 1978 Evinrude 140hp Model #140843c Serial #336438.
many thanks.
Gus
rolmops
Re: Extra Long Leg
They use 25 and 30 inch legs on cape cod bay to make sure that no waves will come crashing in on the stern
oldboat1
Re: Extra Long Leg
Hey Gus -- what's the current length, and what are you after?
gusthewonderslug
Re: Extra Long Leg
Oldboat1
The current leg is a standard long leg, so i'm led to believe, its on a mates boat and he needs a longer leg otherwise he will need to modify his transom. obviously if a longer leg is available it would be preferable to modifying he transom.
Gus
oldboat1
Re: Extra Long Leg
terms might be a little misleading -- different meanings to diff. people. For that reason, I think it would be good to get measurements of the existing motor leg and the boat transom. If you provide the measurements, there will be no misunderstanding. "Long" normally means 20 inches (for a 20" transom).
emdsapmgr
Re: Extra Long Leg
The factory made two engine shaft lengths that year: a standard long shaft at 20" and the model listed above: should be the extra long (25") mode. A 30" was not offered that year. If you are looking for 30" components, best bet is to contact the vendor that boobie posted.
