Hi guys,<br />I have a 1991 ford explorer that I will be using to tow a 18 ft. boat that weighs 1500 lbs. I have seen a item called a t-connector on line that you plug into the tail light connectors on the vehicle and then plug it into the trailer connector. It sounds like a great time saver but I do not have a clue as to where you find the connectors on the explorer. I have crawled under the back but do not see any of the wiring to the tail lights. After raising the hatch I found that the tail lights are held in place with two phillips screws. Are the connectors accessable after removing the tail lights? Any help on this would be greatly appreciated. <br />Thanks,<br />Bill
