Skinnywater
- Mar 7, 2002
- 2,065
I've been chasing this gremlin around for a while.
The engine is a 2007 BF90d with a jetpump.
The symptoms are when cruising at or above 4800 rpm for 10-15 minutes the motor starts a minor surge. Soon after the surge intensifys to a very rythmic surge that can be as abrupt as 1000 rpm. It never dies or quits and when I throttle back it clears up. If I immediately throttle back to idle it idles very smooth.
If I pump the bulb it somewhat clears up.
Sometimes if I shut down the problem will clear up for another 10-15 minutes.
Sometimes I can go for days without a problem.
I think it's starving for fuel and my instinct says it's a low pressure problem.
This is what I've done.
All harnesses have been checked for tightness.
The fuel tank vent is clear. I've removed the fuel tank supply tube checked the screen and tube and visually inspected the tank internals. There was about 12ft. of 3/8 rubber fuel hose that I replaced with 3/8 copper tube and new hose at the ends. The spin on fuel/water seperator is new. The primer bulb is new and all have been triple checked for kinks or obstructions.
Fuel flows freely throught the Honda seperator, through the Honda filter to the low pressure pump.
At idle the low pressure pump shows 5-6lbs with a guage inline. At 5000 RPM it shows 3-4 lbs.
At idle and checking low pressure volume at the inlet of the vapor seperator is......16 fluid ounces in 40 seconds...... I'm suspect here.
My experience on automobiles tells me this fuel pump volume is lacking quite a bit. But then it is a small pump.
If I pump the primer bulb while checking volume at idle, the volume is increased dramatically.
Note that there aren't any buzzers and warnings and no check engine light.
It isn't the rev limiter or engine protection system. It is virtually flawless except the surge.
