Exhuast Shutters in 888 Merc.
kwoolard
Hello all!<br /><br />I have read a few posts regarding exhaust shutters in the 888 Mercruiser stern drives, and most indicate that they are in the base of the Y-Pipe. I was wondering if anyone had an exploded parts view of the Y-Pipe with the exhaust shutters showing their particular location? <br /><br />Secondly, is there anything I would notice by looking at the base of the Y-pipe to indicate they are there without taking the Y-pipe off?<br /><br />Thanks in advance!<br />Keith
Re: Exhuast Shutters in 888 Merc.
<br />The Shutters are #30.........<br />The pic is deceiving,... The T fitting bolts directly to the transom assembley,+ the 2 downpipes go in either side,.....<br />There'll be a Shutter on Each side.....<br /><br />Looking Down from the top,..... You Won't see them...........<br /><br />Looking In thru the Gimbel,...... You Shouldn't see them..............<br /><br />I think, even with the 3 piece Y pipe,......<br />You'd probably Not want to try to take it Off,..... Unless the motor was already Out........
kwoolard
Thanks Laddies and Bondo. That website is perfect for a part search.
JasonB
"Secondly, is there anything I would notice by looking at the base of the Y-pipe to indicate they are there without taking the Y-pipe off?"<br /><br /><br />The only way I knew mine were shot was when I found one of the ears hanging out the exhaust hen I pulled the drive. I don't think you can tell visually if they are there without pulling the Y pipe, unless you could pull the drive and gently prod with a piece of wire to see if it gets stopped?
Ya mean like This,..???.........<br /><br /><br />
<br /><br /><br />This is an Alpha GenII,...... But you get the Idea.........
JasonB
Yup, just like that, except there was just the metal plate from one and the other was burned to a crisp.<br /><br />Made me wonder how the previous owner was running it.
