I'm finishing up the tweaking of my '61 75 johnson....I cannot recall should there be exhaust exiting the discharge hole with the coolant water. <br /><br />Also the starboard side cylinders are running much hotter than the port side. I removed & inspected the thermostat box and fired the motor up & water is pumping thru, new impeller also. Are the 2 sides of the therm box separate for each side or the motor or are the all one system. There are the 2 set of springs one weak the other quite stiff. Can someone explain how this type cooling system works. Ran motor for 20+ min. and never had more than a light spray from discharge hole, even at 2 to 3000 rpm.
