Exhaust Ports on 2.3l cobra outdrive
snowforfun4
View attachment Exhaust.pdf
Is there an exhaust port behind the anode in addition to the prop on the 2.3l cobra (88 bayliner)? Started on muffs to winterize and noticed exhaust blowing back at the transom.
HCMQA
Re: Exhaust Ports on 2.3l cobra outdrive
it's actually in the transom shield not where you have your arrow and it is normal. only really goes through prop when the rpms (and pressure) are high
Don S
If you have water coming out there, the bellows is probably shot. Hope you don't run it that high. Shut it off, and raise the drive and have a look at what could be leaking from the area.
snowforfun4
Great and thanks for the reply. I looked all through the shop manual for it and it did not address the actual exhaust path.
snowforfun4
No water there, only exhaust. Nope, never run it that high, no more than about 1/4 trimmed up for shallow water.
