I'm getting an exhaust noise comming from the bellow that connects the exhaust manifold to the exhaust pipe. I'm thinking that maybe theres a restriction on the flow of water going into the exhaust manifold, the copper pipe that connects the heat exchanger to the exhaust manifold has been soldered a couple of times and there is a slight kink in it, and when i take the lid of the water strainer with the engine running and at idle, water spills out. the engine tempature stays at 185 deg so thats not a problem. my question is, should water spill out of the strainer with the engine at idle ?<br />this is a volvo aq 125 a....thanks
