Finally getting down-n-dirty; here's the beginning of many questions. <br /><br />I have a '77 Sea Ray (SRV197) we put a new block in and I'm replacing the previous log manifolds w/ Osco/Barr center risers. The instructions that came w/ the manifolds were sparse. Apparently they're are different options for the water hoses.<br /> http://www.perfprotech.com/Home/Techtips/marine exhaust manifolds.htm <br />I'm debating between the 1 hose & 2 hose options.<br />Here's a pic of the dry fit of my setup.<br />
<br />Any advantage of 1 vs. 2 hoses?<br />The manifolds have inlets fore & aft, both appear to be level. The front inlet would be easier to plumb, but the rear would be lower when under way w/ the bow up. Does it matter what inlet I use?<br /><br />I thought about running the hose from the thermostat housing to the front inlet of the manifold and also to the riser via a 'T' fitting in the water hose coming off the thermostat housing. Thoughts?<br /><br />Sorry for the long post.
