Re: Exhaust manifold not the fix
Although I won't say it can't happen (strange things often do happen in this world...) the manifold itself may be the least likely cause of overheating. There is nothing in the interior of that manifold (or, rather there is not _supposed_ to be anything) that could in and of itself cause overheating or steam.<br /><br />An overly hot manifold is (usually) caused by bad plumbing or bad water flow. A water flow issue could be before the manifold or after it.<br /><br />But, as you stated that the other side had been replaced already, that it was getting hot, and that now the other side is getting hot I am tempted to think that you have adequate water flow, even if only just, and that the newer manifold is processing it better (less scale and rust in the interior). It is always worth checking the manifold in any case.<br /><br />But I would still suggest that in your efforts that you *make sure* of your plumbing - copying what was there by the prev owner does not necessarily make it right.
