Re: Exhaust Flapper, Discontinued, now what?
i've also searched and not found an answer, they do seem like a good idea as a saftey percaution...i cant find a replacement anywhere!!! some please help!!
so far i found this on the internet
"VOLVO SERVICE BULLETIN Group 25-2 No. 5
Volvo gas sterndrive engines: 3.0, 4.3, 5.0, 7.4, 8.2
Manufacturer discovered that exhaust flapper valve (parts
#3653854-1, 3852753-7 & 3855517-3) in exhaust pipe is not effective
in preventing water ingestion. The valve has a short life span & has been
known to disconnect from its pivot rod & clog exhaust. Manufacturer no
longer installs on affected engines. Mechanics are instructed to remove
flapper valve & not install new ones, attachment holes in exhaust should
be filled w/ silicone or RTV sealer. Volvo also recommends >14" (!!!!) rise
in exhaust. "
sounds like my situation, my riser is well above the water level, my transon would have to be under water for water to get up higher than the riser....still if im out in some seas i dont want to worry about this!!!
