Exhaust Exit
UK_Bayliner
Sorry if this is a silly question, but where does the exhaust exit the boat/outdrive on a Mercruiser 3.0 /Alpha One combination ?<br /><br />I was under the impression that it came out through the centre of the prop, but mine looks as if it is coming through the area around the transom bracket.
Don S
Re: Exhaust Exit
When running, the exhaust comes out the prop, but when at idle there are 2 idle reliefs on the transom shild that allow the exhaust out without going through the prop.
UK_Bayliner
Re: Exhaust Exit
Thanks Don,<br /><br />That explains it.<br /><br />Regrads<br /><br />Nick
Ag97
Re: Exhaust Exit
I was going to ask the same thing. Glad I found this. One more thing, Even when I put the prop into gear the amount of water coming out of the prop didn't seem to change. Is this normal?
Re: Exhaust Exit
Ayuh..... Normal.......
