Re: Exhaust Bellow
This is a OMC Cobra. 400 model i belive. Im beggining to wonder if i need to sale this boat. Just replaced the floors. Last year when i had the boat in water I started to hear the viberation from the outdrive. after reading posts in here i wonder if its the gimbal bearing, also i noticed the shifter cable connecting to the outdrive has a worn spot in it (plastic around it) to the point that the metal casing around the cable is exposed. So if i am correct Gimbal Bearing, 3 bellows, might as well change the u joints, shifter cable, shifter boot, Anything else?
