I went to replace my Exhaust bellow because I saw that it was riped at the bottom Part # 911814 very thick and strong. ordered a new one part #N-182764, very thin and light, and has holes at bottom of bellow. Is this ok to use,
Yes, you should have one. The reason the exhaust bellows are there is to direct the exhaust through the prop (Props are designed for that) instead of on the outside of the drive. and getting all those air bubble into the prop blades path. It will slow you down.
Re: Exhaust bellow omc replacemt has holes in bottom is this ok ?
Once you are under way the bellow is no longer underwater. Therefore it will not introduce air into the prop. Now how fast you need to be going for it to be exposed is hard to say.
