Re: Exhaust assembly melted rubber boots
I just had the same problem yesterday when I was working on my motor. I didnt melt a hole, but I did get alittle white smoke off the rubber boot. My motor wasnt overheating, and I was getting water pumped through my system. However I didnt think it was at a high enough pressure. I tightened the connections from the sea water pump, and the heat exchanger and it fixed my problem. I got better water flow. A few turns of a wrench on your cooling system might fix your problem. Just an idea.
