smokin gun
- Mar 9, 2008
- 6
I just ran my boat for the first time after the winter months.
There was excessive blue smoke while running, really bad when idling. When I got it out of the water I noticed milky oil in both the prop shaft and the exhaust port (what i think is an exhaust port) located in the back under the water pump indicator hole.
This unit has a remote oil reservior that I recently removed and put back in. There are two lines running from this remote oil reservoir and I'm not sure if I put them on correctly. If I got them backwards would it cause this excessive smoke and milky oil.
Also, the motor seem to run fine but at full throttle I could only max out at 43 mph where normally I can hit 50 mph.
Any help would be appreciated
