Chrysler LM 318 engine lots of smoke from breather and dipstick tubes. Compression check revealed good numbers. Motor has tubes from valve covers to flame arrestor no PCV system that I can see. Edelbrock 1409 carbs. Can't understand why I have good compression but a lot of blow by. Port side normal. Motor had valve job some time ago but was run very little until lately. Took it out twice and last time noticed smoke when back at dock. Thought I heard pinging when trying to wind it up. Wouldn't get above 290o rpm. Port side 3500+. Seems like a lot of smoke to be feeding into the carb. Perhaps that causes the pinging?
Also seems to be pushing water out of the cap. I see bubbles in exp. tank with cap off. Could head gasket leak have anything to do with blow by?
At this point thought I may try and torque the head a bit more. Was done to 85 ft. lbs. but I see addendum in manual that says 105 ft. lbs. Can torqueing head more cause more problems with the gasket. I feel I have nothing to lose as I may be yanking the engines for a couple of new long blocks soon if my rings have problems anyway.
Any thought or suggestions would be appreciated.
Best, Stu
Best, Stu
