evinrude
prezz
i have a1956 30hp...and i need to change the lower end...can i use the lower end off a 25hp...they look very close...prez
OBJ
Re: evinrude
Hi prezz...<br /><br />Check that the drive shaft splines are the same and the bolt holes will match to the midsection. Usually lower units from this time frame can be interchanged with no problems.
Chinewalker
Re: evinrude
The only 25hp that will interchange with the 1956 30 is the 1955 25hp (Evinrude model 25018 or 25019 or Johnson model RD-17). 1954 and prior had a different bolt pattern and different water uptake method...<br />- Scott
